Thread: Hide all objects of same family
    2012-02
    Iran,Tehran
    8
    Default Hide all objects of same family
    Hi everyone
    I am an architect and linked mep to my revit file
    we have "exhaust fans" and "Packaged Water Chillers"
    now,I want to hide all "exhaust fan" in roof plan,
    so
    -if I unmark the mechanical equipment in V/G , all of them...hide
    -I can not say to mep team to specify a workset for "exhaust fans"
    -and it is impossible to select one by one with tab and hide them
    Thanks to show me the best way
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,439
    Default Re: Hide all objects of same family
    You will make a filter that uses that category and family name, then you can uncheck the visibilty.
    Scott D. Brown, AIA
    Project Coordinator | Director of Building Information Modeling
    HHCP.com
    2004-06
    Memphis TN area
    6,700
    Quote Originally Posted by sbrown View Post
    That works for objects in linked files? Nice to know if it does. We've had a similar situation where our MEP engineer's thermostat family was set up as Mechanical Equipment, with a circle and "T" in it. The only way I could turn them off was to turn off Mech Equip but then that also turned off all their ground-mounted HVAC units and other things. I finally got them to update the family to have an annotation for the circle with T in it, so I could at least just turn off annotation in their link.
    Intern Architect, BIM Manager/Coordinator
    AERC, PLLC
    Hernando, Mississippi
    Revit - all up in your voxel space
    2012-02
    Iran,Tehran
    8
    it is a good way
    thanks alot
  1. Hide Objects in Different Viewports
    By bradg in forum AMEP General
    Last Post: 2008-08-25, 07:59 PM
  2. Hide Objects in Different Viewports
    By bradg in forum ACA General
    Last Post: 2008-08-25, 02:21 PM
  3. Hide objects in Viewports
    By zfoland20 in forum AutoCAD General
    Last Post: 2004-09-13, 04:37 PM
  4. How to hide objects below grade?
    By thalim in forum Revit Architecture - General
    Last Post: 2003-12-04, 10:02 PM
