Thread: How do you set-up your remote offices for AutoCAD (and/or Revit)
    2000-10
    Orlando, Florida
    38
    Default How do you set-up your remote offices for AutoCAD (and/or Revit)
    Our inter-office connections are MPLS data circuits with T1 data connectivity (some bonded). We have Riverbed devices between the offices. Our cad workstations are Windows7, either 8 or 16 gig of ram, running at Adsk recommended specs. I've read various post that suggest things to check when you have network issues, and I've worked my way through many of them.
    I'd like to hear from those of you with a successfully implemented wide area network for remote offices (success defined as no problems with the speed at which cad software operates, generates plots, no lag time with commands from tool paletttes, etc.). I'm not doing this as a poll because I'd like a bit of information about why you did what you did.
    Do you have remote/redundant/mirrored servers at each site?
    Do you use custom profiles at each site?
    Do you store you libraries and lisp routines on remote servers or on the workstations?
    Do you use Autodesk Vault so people can work on the file locally?
    If you use remote servers, were you able to set up a single set of tool palettes that you could deploy to any office, or did you have to set up palettes for each office? If you were able to use a single set of tool palettes, how did you do it (yeah sort of a separate topic)?
    Thanks
    Earth
    9,805
    Default Re: How do you set-up your remote offices for AutoCAD (and/or Revit)
    See interspersed answers below.
    Quote Originally Posted by Mitch Mermel View Post
    Do you have remote/redundant/mirrored servers at each site? Yes
    Do you use custom profiles at each site? Not sure what you mean exactly, but the machines in each local office point to support files in that office.
    Do you store you libraries and lisp routines on remote servers or on the workstations? On the local office's server
    Do you use Autodesk Vault so people can work on the file locally? No.
    If you use remote servers, were you able to set up a single set of tool palettes that you could deploy to any office, or did you have to set up palettes for each office? Yes. If you were able to use a single set of tool palettes, how did you do it (yeah sort of a separate topic)? Short answer, they are part of our DFS file mirroring.
    Thanks
    R.K. McSwain | CAD Panacea |
  1. MEP model sharing between remote offices
    By mark_hartman in forum BIM Management - General
    Last Post: 2011-12-06, 08:25 PM
  2. How to deal with remote offices
    By andrew.139822 in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2009-09-21, 12:24 PM
  3. Remote Offices
    By pmccord in forum Design Review - General
    Last Post: 2008-11-06, 05:55 PM
  4. Revit, Riverbeds, Worksharing, Remote Offices
    By pdavis in forum Revit - Hardware & Operating Systems
    Last Post: 2006-10-13, 03:21 PM
  5. Connecting remote offices
    By gtokita in forum Networks
    Last Post: 2005-12-29, 08:28 PM
