Thread: Visibility State "walk" sim to LayerWalk
    I could stop if I wanted to cadpoobah's Avatar
    2003-12
    Central Ohio
    417
    Default Visibility State "walk" sim to LayerWalk
    In the Block Editor, it would nice to have a way to easily "walk" through the available visibility states. I realize you can pick the VS from the dropdown in the Visibility panel on the ribbon, but it seems that if I could "scroll" thru the available states with the up & down arrow keys (think LayerWalk!), it would be alot quicker. And would make it easier to quickly "toggle" between two states to compare them.
    Using VLisp, how can I get a list of VS's? Is it possible to create a modeless dialog (again, think LayerWalk) showing all the VS's that I could "walk" through with my keyboard? Possibly even a option in it to toggle the Visibility mode (BVMODE) on or off. And while I'm wishing, it would be nice to be able to display multiple VS's at the same time (similar to BVMODE=1) but only showing the VS's that are selected.
    Any thoughts/ideas/takers?
    Thanks!
    Moderator BlackBox's Avatar
    2,384
    Default Re: Visibility State "walk" sim to LayerWalk
    Look into the Allowed Values of the DynamicBlockProperties Object for the available Visibility State(s).
    "Potential has a shelf life." - Margaret Atwood
    2007-07
    Jo'burg SA
    4,344
    I'm guessing you are referring to VS inside the BEdit environment. If so then the only way to change the VS is to issue a command for BVSTATE using it's command-line version's Set option and the state name. Though then you'd need to close the dialog before issuing the command, then reopen the dialog, so it would cause a flickering effect at best.
    What I'm really upset about is the drop-down for VS choices. It's possible to keep it in focus then use the up/down and enter on the ribbon based one. But the older version looses focus as soon as you change the VS. If the focus was kept you could "walk" by pressing the up/down keys. At the moment you can only do so with the ribbon turned on, yet you need to press <Up><Enter> or <Down><Enter>
    The BVMode is much simpler to do since this is a setvar operation, no need to close the dialog.
  1. State Troopers get "crash" course in Forensic Animation
    By stusic in forum DV - The 3rd Dimension
    Last Post: 2007-07-09, 06:57 PM
  2. Crashing in "Walk" mode
    By guyayers in forum AutoCAD 3D (2007 and above)
    Last Post: 2007-06-26, 12:33 PM
  3. Toggle Layer (Part Duex) "A State of Frozen"
    By madcadder in forum AutoLISP
    Last Post: 2005-04-26, 09:52 PM
  4. "Revit Redefines State of the Art" in the Latest Issue of HotNews
    By richard.binning in forum Revit Architecture - General
    Last Post: 2004-06-04, 10:32 PM
  5. Design Options Visibility "Automatic" v. "Pri
    By narlee in forum Revit Architecture - General
    Last Post: 2004-03-27, 05:16 AM
