Thread: changing door swing in a door legend
    2010-03
    4
    Default changing door swing in a door legend
    How do you change the door swing of a door legend? I tried mirroring but it doesn't work. The door symbol is inserted but can't be rotated or even flipped. Any work around?
    2015-11
    Madison, WI
    1,318
    Default Re: changing door swing in a door legend
    If you are looking at an elevation of the door panel, then select the door and up at the top there should be a drop down for element view. Change this from front to back.
    Cheers,
    Jeff S.
  1. 2013: Door Family - Frame Types - Door Schedule - Legend Component
    By bmaxwell143848 in forum Revit Architecture - Families
    Last Post: 2012-10-29, 01:45 AM
  2. Door Swing Disappears when door is flipped
    By dannycerezo in forum Revit Architecture - General
    Last Post: 2010-02-06, 09:40 PM
  3. Door family w/ curved swing new and straight swing existing
    By ericsson in forum Revit Architecture - General
    Last Post: 2007-12-19, 04:02 PM
  4. Parametric Door Swing w/ Nested Door Slab
    By Recdiver in forum Revit Architecture - Families
    Last Post: 2007-05-11, 08:07 PM
  5. Attaching a door plan swing to the door leaf?
    By patricks in forum Revit Architecture - Families
    Last Post: 2005-03-24, 07:56 PM
