Thread: Problem: Revit custom revit.ini file linked to creation location in deployment image
    2008-10
    Auckland, New Zealand
    115
    Default Problem: Revit custom revit.ini file linked to creation location in deployment image
    Hello...
    Not sure if anyone else has noticed that Revit 2013 looks back to the original location that you loaded your custom revit.ini file during the installation of the file, even tho it's loaded into the deployment image.
    There is a version of the custom ini file located in the deployment image (<servername>\<deployment_location\AdminImage\CustomSettings) which will contain any customisations you made to the ini file.
    BUT if you have a look at the RevitCustom.log:
    => Get: SourceDir: \\<server2>\SMSPKGS$\AKL00620\AdminImage\x64\RST2013\
    => Looking for \\<server2>\SMSPKGS$\AKL00620\AdminImage\x64\RST2013\inifile.xml
    => Get: REVITINIDEPLOY: \\<server1>\packagingsource2$\Autodesk\Revit Structure 2013\AdminImage\CustomSettings\\Revit Structure 2013_Revit.ini
    => Setting CustomActionData for RvtWriteIni to C:\WINDOWS\TEMP\aec4EC1.xml;\\<server1>\packagingsource2$\Autodesk\Revit Structure 2013\AdminImage\CustomSettings\\Revit Structure 2013_Revit.ini
    => Set: RvtWriteIni: C:\WINDOWS\TEMP\aec4EC1.xml;\\<server1>\packagingsource2$\Autodesk\Revit Structure 2013\AdminImage\CustomSettings\\Revit Structure 2013_Revit.ini
    If you have a look in the RST2013-Revit Structure 2013.mst (\AdminImage\x64\RST2013) which is applied to the RST2013.msi:
    Under the properties table the locations of these files are hard pathed and not variable based on the deployment location:
    REVITINIDEPLOY \\<server1>\packagingsource2$\Autodesk\Revit Structure 2013\AdminImage\CustomSettings\\Revit Structure 2013_Revit.ini
    REVITINIUSERSOURCE \\<server1>\packagingsource2$\Autodesk\Revit Structure 2013\Revit.ini
    REVITINIDEPLOY = is the location i created the deployment
    REVITINIUSERSOURCE = the location where i loaded the custom revit.ini file from, this did change to the location of the different machine when i loaded it from the different machine as a test.
    So even tho Revit was being installed from server 2 it's referring to server 1 for the custom revit.ini file content, i'm not sure what else it's referencing from the original source location at the moment.
    Anyone else had this issue, or gotten around it without editting the msi?
    Active Member hermeytheelf's Avatar
    2007-06
    57
    Default Re: Problem: Revit custom revit.ini file linked to creation location in deployment image
    Heath, I just replied to another thread that you were the latest member to post.
    http://forums.augi.com/showthread.ph...how-to-s/page2
    Have you found a way around this yet? Did you move your custom .ini file and re-run your deployment on a new machine and found that it failed to apply the settings?
    2007-06
    57
    Also I have found that there is a long thread on wiki help about this with no real solution either
    http://wikihelp.autodesk.com/Revit/e...68-Why_aren168
  1. 2014: Revit 2014 Deployment Image Size Reduction
    By heath.simone in forum Revit - Platform
    Last Post: 2013-05-08, 05:43 AM
  2. Replies: 2
    Last Post: 2012-12-04, 12:01 AM
  3. Revit 2012 Deployment Creation
    By jrostar in forum Revit Architecture - General
    Last Post: 2011-06-09, 03:42 AM
  4. Problem with linked file location
    Last Post: 2008-04-03, 04:32 PM
  5. Replies: 2
    Last Post: 2006-03-09, 01:27 PM
