de243
I don't know if anyone else has run into this in Revit 2013, but if you have, I'd love to know the solution.
I want to select a datum line, but when I try to pick the line it moves the entire datum 2.5' up.
Thx for the help.
Re: de243
After selecting an object, the whole screen 'wigs out' as the Options Bar adds extra pieces and then goes back to normal, right? I don't remember exactly what causes this - I ended up getting a new computer and it resolved itself. In the meantime, docking the Options Bar at the bottom should fix it. The status of Press & Drag may have an effect as well.
Re: de243
I'm not having the wig out problem, thank goodness. I should also mention that the datum show as being locked. I'll check into the options bar, however these are datum that are already set. I was selecting them after they have been set and locked.
Re: de243
You mentioned that the displacement is 2.5 feet. Does that value change based on how closely you are zoomed in? Also, by 'locked' do you mean pinned?
Re: de243
After closer examination, the 2.5' dimension doesn't seem to be consistent. It does seem to make a difference depending on how far in/out the zoom is. By locked I mean it has the little padlock symbol that is closed not the thumb tack or whatever that type of pin is called.
- You may not post replies
- You may not edit your posts
Forum Rules
