Thread: Exfiltration Trench (Trench, Casing, Reinforecement around pipe)
    Wish List Administration
    2011-08
    4,581
    Default Exfiltration Trench (Trench, Casing, Reinforecement around pipe)
    Summary: Ability to have a Trench, Casing, Bank or Reinforcement around a pipe which will be linked to the pipe and its properties
    Description: Ability to enclose a pipe with a Trench, Casing, Bank, or Reinforcement material which will be linked to the properties of the pipe and its location. This material outside the pipe would also have properties of its own which are independent from the pipe's properties (i.e. depth, width, material, length, etc)
    This would be very useful when showing shallow pipes which need to be encased in concrete in only a certain area. Also for Exfiltration trench which starts and stops a few feet away from the structure and its dimensions depend upon the geotechnical values of the material around it and the municipality.
    Product and Feature: AutoCAD Civil 3D - Pipe Network
    Submitted By: Andres Aristizabal on Tue, 12 Jun 2012
    2011-08
    4,581
    Exclamation Re: Exfiltration Trench (Trench, Casing, Reinforecement around pipe)
    Submitted By: Andres Aristizabal on 06/12/2012
  1. 2012: Exfiltration Trench
    By AAristizabal in forum AutoCAD Civil 3D - Pipes
    Last Post: 2011-10-20, 03:16 PM
  2. Trench Drains - questions...
    By tcapmusic in forum AutoCAD Civil 3D - Pipes
    Last Post: 2009-06-03, 01:09 PM
  3. Civil - Trench B detail (Plan View)
    By Mlabell in forum Dynamic Blocks - Sharing
    Last Post: 2007-02-18, 05:37 PM
  4. TRENCH FOOTING W/ MASONRY WALLS
    By mrowen in forum Revit Architecture - General
    Last Post: 2005-09-29, 02:24 PM
  5. Trench Drain, Anyone?
    By bowlingbrad in forum Revit Architecture - Families
    Last Post: 2005-08-27, 03:16 AM
