Hi,
Thanks in advance for the help!
We've had electrical circuits disconnecting from their panel when a sync is performed. The circuits are intact (including load name and circuit number), but no longer connected to the panel. You can simply reconnect the circuit to the panel and everything is back to good, until you sync again.
We've found a few frustrating work-arounds that sometimes work:
- Delete the panel and insert a new panel in its place, reconnecting all circuits.
- On Switchboards, increase the "Max #1 Pole Breakers" to some number much bigger than what you actually need. We think this is related to the other switchboard bug where you can't connect anything more to your switchboard even though you still have spaces (if you don't know what I'm talking about, just ask and I'll explain this more).
So, can anyone else help me understand this bug or help with fixes/workarounds that work consistently?
Ryan
Electrical Designer
Revit MEP 2012
