Results 1 to 7 of 7
Thread: XREF Objects on Layer 0 won't display liinetypes in drawing
    2005-01
    115
    Default XREF Objects on Layer 0 won't display liinetypes in drawing
    I have an Xref with some objects on layer 0, In my drawing when I place the Xref on any layer the color is correct but the linetypes only show as continuous. This happens regardless of the layer or linetype I choose
    Everything is set to by layer
    the Xref and the drawing are set to the same Linetype scale (not sure if this matters)
    any ideas?
    Thanks
    Mike
    Mac
    2008-03
    326
    Default Re: XREF Objects on Layer 0 won't display liinetypes in drawing
    I have similar issues where we have drawings from other firms. The issue is acad.lin and acadiso.lin. I fixed mine by going to all the drawings from other firm and command linetype / locate acad.lin / select all the linetypes and reloading all of it, if it still not showing the right linetype you need to re-attached xref. If you need to do these on numbers of drawing I think having an lsp would be a great help. Also, custom linetype is another issue.
    All AUGI, all the time arshiel88's Avatar
    2005-02
    Off the Grid
    548
    The objects within the XREF should be ByLayer to show the Layer's linetype, or ByObject to be able to set its own linetype. It cant be "Continous" or any other linetype otherwise it will always be Continous no matter what you set in the drawing where it is referenced.
    If that doesn't solve the problem, an LTSCALE/PSLTSCALE issue maybe?
    or
    Play with the MEASUREMENT value, then reload linetypes.
    Shielbern Bolalin
    Architectural 3D Renderer
    “A clever person solves a problem. A wise person avoids it.”
    1879-1955
    2005-01
    115
    Okay, I figured it out, When I did a Layer Merge from the consultants layers to Layer 0, The consultant had changed the properties of their layer so nothing was set ByLayer
    Quick fix, sorry for the oversight, I should have caught this in the beginning,
    thanks everyone for the suggestioins
    Mike
    Mac
    AUGI Addict tedg's Avatar
    2005-06
    in the upper right corner
    2,293
    Quote Originally Posted by jocques View Post
    ....The consultant had changed the properties of their layer so nothing was set ByLayer
    They should be STOOGE SLAPPED!!!!
    Then Tarred and Feathered!!
    Ted
    ____________________________________________________________________________________
    AutoCAD 2012 - REVIT Structure 2012 - MicroStation V8i - Windows 7 Professional - (dabble with Inventor 2012)
    Certifiable AUGI Addict Wanderer's Avatar
    2001-12
    St. Louis
    4,259
    In order to address this, I'm waiting for Autodesk to add a 'corporal punishment' add-on... it'll reach out of the monitor and smack silly anyone who tries to change something from ByLayer.
    Melanie Perry @MistresDorkness
    Facilities CAD Management (FM - MEP/FP)
    Technical Editor
    Revit MEP 2013 Suite
    not all who wander are lost
    2008-03
    326
    upgrade the "checkstandards" command
  1. Objects not visible in drawing with xref.
    By neilcheshire in forum AutoCAD LT - General
    Last Post: 2007-06-07, 02:35 PM
  2. Replies: 8
    Last Post: 2006-01-13, 05:55 PM
  3. control display properties of an Xref'd drawing
    By crbickel in forum ACA General
    Last Post: 2005-08-14, 06:58 PM
