Thread: I can't get my head around sheet sets :(
    Default I can't get my head around sheet sets :(
    I have 10 designs for new frames my company is building, all based on an original design but with modified parts. There are 5 parts, some frames use the same parts.
    My company wants a set of sheets for each frame, including a title page, views of the completed frame, and an appendix of the parts used in the particular frame.
    I haven't been able to get my head around why you cant have a layout in multiple sheet sets. say frame 1,2 and 3 all used parts AAA and BBB, and i make a sheet set for pdf publish for frame 1 including layouts for AAA and BBB, then when I come to make a sheet set for frame 2, i cant include AAA and BBB. I don't want to have to copy a layout and use this (plus by doing so, id have to make changes to multiple layouts when a single part changes). I could print off all the layouts individually and sort them manually but this requires a lot of effort and undermines the feature of having sheet sets.
    Am I going about this all wrong, or am I overlooking a setting? Any help would be greatly appreciated as I'm tearing my hair out.
    I could stop if I wanted to Norton_cad's Avatar
    2007-05
    Bardwell Valley, Sydney, Australia
    433
    Default Re: I can't get my head around sheet sets :(
    It sounds like X-ref's of the five parts, would give the control you seek.
    Ohm's Law - Electricity follows the path of least resistance.
    Regards,
    Mark Norton,
    It does thank you, Ive been following the sheets happen! tutorial and its given me the flexibility I need.
    The only problem is when using an xref, and viewing through a viewport with shadeplot legacy hidden.... it ignores the plot styles, and a lot of people have asked why over the years but no one has recieved an answer, Im tearing my hair out
  1. Sheet sets.....
    By tcalabrese.210180 in forum AutoCAD 3D (2007 and above)
    Last Post: 2009-03-01, 12:15 PM
  2. AutoCAD 2008 - Sheet Set Manager no longer opens sheet sets
    By sjz in forum AutoCAD Sheet Set Manager
    Last Post: 2007-08-23, 03:09 PM
  3. SHEET SETS
    By rstiles in forum ACA General
    Last Post: 2005-11-28, 09:43 PM
  4. Sheet Sets in VB
    By elise_moss in forum VBA/COM Interop
    Last Post: 2005-02-28, 06:42 PM
  5. Sheet Sets
    By MikeM4OSU in forum ATP Course Wishlist
    Last Post: 2005-02-17, 01:48 PM
