Thread: Tag the elevation
    Wish List Administration
    2011-08
    4,584
    Default Tag the elevation
    Summary: Several items have the ability to tag part of it elevation, you can tag the invert elevation of a pipe, as long as you want the elevation of the closest edge. You can tag the bottom of a struct foundation but you cannot tag the top. Give us access to all the elevation possibilities.
    Description: So you have a foundation tag that will tell you the bottom elevation of the foundation and you can tag the thickness of the foundation, but not create a parameter to create the top of the elevation. That has to be done with the spot elevation tag. Pipes and ducts have similar issues.
    Tags can read and display part of the information.
    Parameters can be added but cannot be used in formulas to get the true desired display in the tag. I want to be SURE that the tops of all foundation are at the correct height and I want a symbol that goes along with it.
    Just allow access to the spot elevation information to calculate other desired elevations.
    Add same for pipes and ducts.
    Product and Feature: Revit Structure - Annotation Tools
    Submitted By: Steve Saltsman on Mon, 18 Jun 2012
    2007-03
    5
    Default Re: Tag the elevation
    Resolved in Revit 2015, I believe.
    2011-08
    4,584
    Exclamation Re: Tag the elevation
    Tag the elevation
    Submitted By: saltsmans on 06/18/2012
  1. 2016: REVIT 2016: Spot elevation/Invert elevation for fabrication part.
    By swapr78 in forum Revit MEP - General
    Last Post: 2015-07-03, 11:52 AM
  2. 2013: Elevation Editor Jumps to Bottom of List after Editing Elevation Value
    By aspencer.226869 in forum AutoCAD Civil 3D - General
    Last Post: 2014-03-21, 07:01 PM
  3. 2013: How to import AutoCAD elevation drawing into Revit Elevation
    By akamildxb in forum Revit Architecture - General
    Last Post: 2013-05-29, 01:58 AM
  4. associating global elevation and building elevation on a single level....
    By olakahahola in forum Revit Architecture - General
    Last Post: 2007-11-07, 08:33 PM
  5. Replies: 9
    Last Post: 2006-08-24, 11:46 AM
