Results 1 to 10 of 10
Thread: Horizontal Dimension with Vertical Text between extension lines.
    2006-01
    29
    Question Horizontal Dimension with Vertical Text between extension lines.
    I would like to know how we can achieve a Horizontal Dimension with Vertical Text between extention Lines of a dimension as shown in the attached file.
    Regards,
    Ravish Ghaty
    0,0,0 The Origin
    8,570
    Default Re: Horizontal Dimension with Vertical Text between extension lines.
    I can't do it with a dimstyle or text style but text rotation = 90 in properties manager almost does it.
    You can change many at once or change one instance and use matchprop to change the others.
    2009-02
    Newcastle N.S.W. Australia
    36
    As Jaberwok says you can rotate the text in properties manager.
    If you then stretch the text you can get what you want. To stretch
    just the text you must pick just the text with the crossing window.
    Multiple text can be selected for the one stretch command.
    Note: make shore that the fit is set to 'move text, no leader'.
    A bit of work, I know, but that is the only way I can see.
    Hope this is of help.
    Regards
    Johnb
    All AUGI, all the time arshiel88's Avatar
    2005-02
    Off the Grid
    560
    In Dimension style, choose Horizontal in the Text Alignment option.
    The trick is this, before you make dimension, rotate UCS by 90 degrees so that the "horizontal" becomes "vertical". Do the same for other orientation.
    2012-05
    28
    But the only 'problem' is you have to move text above the dimension line manually, because rotated text is always place in the middle of the line 'breaking' it. So, a lot of manual work and no simple setting or system solution to the OP's issue, maybe some lisp...
    2005-02
    Off the Grid
    560
    Quote Originally Posted by Blackfish View Post
    Nope, not always. If you choose "Outside" in the Vertical option in Text Placement group, it will always be above the dimension line.
    0,0,0 The Origin
    8,570
    Quote Originally Posted by arshiel88 View Post
    I tried every placement option: they all placed the text throught the line.
    But I hadn't changed UCS so that might be the "secret".
    2012-05
    28
    You're right!
    Quote Originally Posted by jaberwok View Post
    Yes, rotated UCS is the secret. It works
    2006-01
    29
    This works great, Thanks
    2005-02
    Off the Grid
    560
    You're right!
    The architect is always Wright.
    Quote Originally Posted by ravishh View Post
    We're glad we helped.
  1. 2013: Different lines colors when vertical and horizontal
    By jaredk in forum ACA General
    Last Post: 2013-01-02, 07:55 PM
  2. Dynamic dimension extension lines
    Last Post: 2012-10-19, 03:05 AM
  3. Dimension Extension Lines
    By timlane in forum AutoLISP
    Last Post: 2009-02-12, 09:01 PM
  4. Detect lines that are not absolute horizontal or vertical
    Last Post: 2005-10-21, 12:15 PM
  5. Dimension Extension Lines
    By wse1 in forum Revit Architecture - General
    Last Post: 2005-08-26, 08:39 PM
