Thread: Breaking Wires
    2010-05
    85
    Default Breaking Wires
    When two circuit lines cross the wires automatically trim. However when a circuit line crosses a luminaire it does not trim. How do split, trim, or whatever a wire so it does not run through a fixture?
    Kevin L. Yingling, PE
    Principal
    Innovative Electrical Systems Inc
    www.iesystems-inc.com
    I could stop if I wanted to CADastrophe's Avatar
    2012-01
    Site of the next CADaclysm
    386
    Default Re: Breaking Wires
    I think you have to draw two separate wire segments - wires only break for other wires. Best practice would be to not cross the light fixture, which I know is not always possible.
    2010-05
    85
    Yeah in most cases I do avoid this but in this case I cannot as I have a perimeter cove with pendants in the middle on two different control relay circuits. The pendants cross the cove. Well two wire segments it is.
    Principal
  1. wires no tags
    By jchand1990726401 in forum Revit MEP - General
    Last Post: 2012-01-25, 10:17 PM
  2. wires or no wires for circuiting
    By EddieFromDc in forum Revit MEP - General
    Last Post: 2010-06-09, 09:01 PM
  3. Wires
    By wags5116 in forum Revit MEP - General
    Last Post: 2010-02-24, 01:42 PM
  4. Wires in section and 3D
    By just_vip2003 in forum Revit MEP - General
    Last Post: 2009-10-26, 12:43 PM
