Thread: Darken Underlay on plots
    2002-03
    278
    Default Darken Underlay on plots
    Having a problem in Revit 2009 with my existing walls on a remodel plotting so light grey I can hardly see them. I know how to darken half tones in later versions of Revit but this project had to be done in 2009. (Long Story)
    Can someone tell me how to get my half tones darker in 2009
    2004-08
    Syracuse, NY
    621
    Default Re: Darken Underlay on plots
    It sounds like you need to edit your phase settings. Under the graphics override tab in the Phase dialog, make sure the halftone box is unchecked for the existing phase. Change the cut and/ or projected line colors to be a darker gray. I believe you can find the phase dialog box under the Settings pull-down menu then Phases? Not sure, its been a while since I used 9
    Jason Coe, Design Technology Manager
    Ashley McGraw Architects
    Syracuse, New York
    ____________________________________________
    "Nothing happens by chance and coincidence is when God wishes to remain anonymous"
    http://revitecture.blogspot.com
    2002-03
    278
    Thanks Jason,
    That worked for now. Still can't figure out why they would appear different in different views w/ the same view settings.
  1. 2012: Underlay RCP and Underlay Orientation
    By SamuelAB in forum Revit Architecture - General
    Last Post: 2012-08-08, 05:27 PM
  2. Mass-darken lineweights for large prints
    By actsrevolt in forum AutoLISP
    Last Post: 2010-06-12, 05:35 AM
  3. 3D DWF plots that are not 3D
    By 3D Jack in forum AutoCAD Plotting
    Last Post: 2005-10-12, 07:32 PM
  4. PDF plots
    By bush.71520 in forum AutoCAD Plotting
    Last Post: 2004-08-24, 11:54 AM
