Results 1 to 8 of 8
Thread: Why did my 3D Cad file double is size?
    2007-03
    East Bay Area of Northern California
    9
    Default Why did my 3D Cad file double is size?
    I am working with AutoCad 2010.
    I am doing a 3D framing model for BIM coordination. I have each floor 1 thru 5 on separate files.
    The file size for each floor is about 10-15 MB. For some reason when I was modifying my floor 2, and 5 file the file size jumped to 70-80 MB.
    I am using the same extruded members all over and just modifying them a little bit. Does anyone know why it would jump up like that and also what could be containing so much data.
    Thanks for your help.
    Member RJStone's Avatar
    2007-01
    Salem, Oregon, United States
    21
    Default Re: Why did my 3D Cad file double is size?
    I doubt this would represent a 50-60 mb jump...but try purging registered applications.
    -purge r
    Can you post the file?
    Reuben J Stone
    Senior Bridge Design Technician
    http://www.linkedin.com/pub/reuben-stone/27/382/893
    2004-08
    Hartford, Michigan
    3,086
    Quote Originally Posted by RJStone View Post
    -purge r
    that large of a file cannot be uploaded here AFAIK
    Christopher T. Cowgill, P.E.
    WIGHTMAN & ASSOCIATES, INC.
    ENGINEERING <> SURVEYING <> ARCHITECTURE
    AutoDesk Infrastructure Design Suite Premium 2013 x64
    Windows 7 Pro x64
    2007-03
    9
    Yeah I definitely tried purging the file of anything extra, including the applications. I think it has something to do with joining and then separating 3D extruded shapes, and or copying them.
    The strangest thing to me is that I have used the same methods on each floor and it's only the 2 that are huge and the others have maintained a normal size.
    0,0,0 The Origin
    8,029
    It might be worth checking the values of SOLIDHIST in each file.
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
    All AUGI, all the time arshiel88's Avatar
    2005-02
    Off the Grid
    548
    After SOLIDHIST as suggested by John, and it turns out that it was enabled, BREP all solids, to remove all history.
    Did you save to previous version?
    Shielbern Bolalin
    Architectural 3D Renderer
    “A clever person solves a problem. A wise person avoids it.”
    1879-1955
    2007-03
    9
    Thank you for your input! My solidhist was set to 0 but by using the brep command I shaved 20 megs of the filesize. So it is still pretty huge but that def helps me out.....
    2005-02
    Off the Grid
    548
    Try to WBLOCK only the needed objects?
    Shielbern Bolalin
    1879-1955
  1. 2011 - Launch by Double Clicking File Icons
    By saeborne in forum Revit Architecture - General
    Last Post: 2010-06-29, 06:09 PM
  2. Allowable Forum file attachment types and their corresponding maximum file size
    By Mike.Perry in forum Forum Tips & Tricks (Read only)
    Last Post: 2007-05-28, 08:19 PM
  3. Obtain best Image file size for placing in drawing file
    By cadmecheng in forum AutoCAD LT - General
    Last Post: 2006-06-02, 07:49 AM
  4. Default to 8.1 when double-clicking an RVT file
    By J. Grouchy in forum Revit Architecture - General
    Last Post: 2005-10-16, 02:19 AM
  5. shape file / dbf file size
    By gis.68227 in forum AutoCAD Map 3D - Wish List
    Last Post: 2004-08-20, 01:35 PM
