Thread: Parametric Detail family (how does this work)
    2010-08
    6
    Default Parametric Detail family (how does this work)
    i have been using just lines to make a similar tree, then found this (i use 3 lines, this uses 2) it works perfectly, scales parametricly, but i don't see how, theres no dimensions or locks. I wanted to add a 3rd line, so i did so and it didn't scale.
    Can someone explain it to me?
    I have attached the tree.
    Cheers guys!
    2009-03
    Somerville, MA
    669
    Default Re: Parametric Detail family (how does this work)
    If you check the visibility/graphics settings, you'll see that all annotation info (ref lines and dims) are turned off. Simply turn them on and you'll see all the parameters.
  1. Revit Structure parametric steel detail
    By ABT-NL Richard Fielt in forum Revit - Gallery
    Last Post: 2010-09-02, 09:08 PM
  2. Parametric Detail Components for BPMs
    By ekoehne in forum Revit Architecture - Families
    Last Post: 2010-06-14, 03:52 PM
  3. Parametric Profile Family
    By MHiermer in forum Revit Architecture - Families
    Last Post: 2010-01-21, 04:57 PM
  4. Detail cut lines - how can I make my detail cut family scale automatically?
    By Margarita in forum Revit Architecture - General
    Last Post: 2009-09-11, 06:48 AM
  5. Parametric Mullion Family?
    By jsteinhauer in forum Revit Architecture - Families
    Last Post: 2009-06-02, 09:48 PM
