Results 1 to 9 of 9
Thread: Component Stair Stringer Extension
    100 Club ghale's Avatar
    2006-07
    Rochester, NY
    121
    Default Component Stair Stringer Extension
    We're trying to rework our stair library to leverage the Revit 2013 Stair Components. I think I've found one hitch that I can't seem to get around. We're creating a concrete metal pan stair with C-Channel stringers. That stringer should extend several inches beyond the first riser for constructability. With stairs by sketch you can easily extend the boundary line to modify the length of the stringer. I can still do this in Revit 2013, but have found a hitch when converting a component-based stair to a sketch. After converting it to a sketched stair, I can extend the boundary, but it doesn't produce any results. I'm not sure if anybody else has started to rebuild their stair library, but let me know if any of you have run into the same issue.2013 Stair Extension.PNG
    Revit BIM Consultant Alfredo Medina's Avatar
    2008-05
    Miami, FL
    986
    Default Re: Component Stair Stringer Extension
    Quote Originally Posted by ghale View Post
    We're trying to rework our stair library to leverage the Revit 2013 Stair Components....
    ...and why are you redoing your stair library? I still don't see the strength of this new method for doing stairs; instead, I have read some reports of things that the sketch method can do, but this new method cannot, like another issue about balusters, in another thread in this forum.
    2006-07
    Rochester, NY
    121
    The new component tools definitely add some more functionality. We want to get rid of the workarounds and leverage the modeling tools instead of drafting what's really needed. The strange piece is that when converting a stair run from component base to sketch, the stair tools don't work the same as the regular sketch mode.
    Active Member ttiefenbach's Avatar
    2009-03
    Orlando, Florida
    71
    Did you have any luck getting this to work? Did you send any kind of support ticket into Autodesk?
    Anthony Tiefenbach, BIM Manager
    HuntonBrady Architects
    Revit Architecture 2013 Certified Professional
    2006-07
    Rochester, NY
    121
    No luck with this specific case. From my understanding, Autodesk is working on finishing the stairs and railing functionality/featureset for 2014.
    2004-06
    Memphis TN area
    6,700
    "Finishing" it, oh great. Probably means we won't have any other cool new features or much-needed fixes and improvements to other stuff *cough* site! *cough*
    'course I wouldn't know as I wasn't invited to alpha or beta test like I was for 2012 and 2013, for some reason.
    Intern Architect, BIM Manager/Coordinator
    AERC, PLLC
    Hernando, Mississippi
    Revit - all up in your voxel space
    2009-03
    Orlando, Florida
    71
    I did open a support ticket with Autodesk and was informed that:
    The application is working as designed. Stair by component will not behave as you want it to. Development added stair by sketch to allow this type of editing.
    Instead I am to:
    Please provide feedback at the below link. Information gathered is used to improve the application.
    Product Contact Link: http://usa.autodesk.com/adsk/servlet...112&id=1109794
    2009-03
    Orlando, Florida
    71
    Quote Originally Posted by patricks View Post
    Me either. I wonder if they are shifting the testers to users who just think everything is awesome.
    2004-06
    Memphis TN area
    6,700
    Emailed the guy at ADSK who had sent me the invitation in previous years. He said they're doing Alpha testing with a smaller group of people and then will be sending out invitation soon for Beta testing to more people. Still seems odd as I tested the Alpha versions as well for both 2012 and 2013.
    AERC, PLLC
  1. Notching a stair stringer
    By klebeck in forum Revit Architecture - General
    Last Post: 2009-12-02, 02:10 PM
  2. Stair Stringer
    By david_peterson in forum Revit Structure - General
    Last Post: 2006-04-05, 08:30 PM
  3. Stair stringer help
    By Kirk Bricker in forum Revit Architecture - Families
    Last Post: 2005-12-09, 09:41 PM
  4. Stair stringer profile
    Last Post: 2005-09-23, 01:34 AM
  5. stair stringer disconnect.
    By ryan.87191 in forum Revit Architecture - General
    Last Post: 2005-06-10, 04:04 PM
