Thread: Grading to surface help
    2008-01
    5
    Default Grading to surface help
    Hi,
    I am trying to grade the outer side of an access track to 1:3 to match the existing ground surface i have created. the fill part of the grading looks okay and what i expected, but the cut isnt, The cut part seems to stop with a straiht line when meeting the fill instead of marrying in. anyone able to offer some advice? cheers
    2001-10
    Arizona
    2,337
    Default Re: Grading to surface help
    try grading in multiple regions along that feature line, and then apply the create transition tool
    Be your Best,
    Michael Farrell
    www.primeservicesglobal.com
  1. Surface nette, surface brute des murs d'une pièce à peindre
    By ph.herrmann in forum Revit Architecture - Général
    Last Post: 2010-01-06, 05:56 PM
  2. How do you creat a surface from a grading group?
    By dorseydesignservices in forum AutoCAD Civil 3D - Grading
    Last Post: 2007-10-12, 05:23 PM
  3. Constrain flat surface to concave surface?
    By MariusvdM in forum Inventor - General
    Last Post: 2007-03-20, 05:38 PM
