Thread: Shading and hiddne lines
    2012-03
    18
    Default Shading and hiddne lines
    So getting the hang of this revit beast slowly but surely. Now I want to get revit to produce some sharp looking drawings not the easiest thing i have realized.
    Here is what i want:
    New duct, duct accessories, duct fittings, new mechanical equipment etc to show shaded. My plan for this is create a shared parameter and manually select yes or no to determine whether the equipment is new or existing. Since you can't use "phased created" as a view filter.
    Problem with this is that when I shade everything like that it hides all the hidden lines which I want to see. If I use a material to shade the ducts and stuff it shows the hidden lines BUT can't figure out how to just add the material to the new stuff not the existing.
    Hopefully you get my drift and thanks for the help
    I could stop if I wanted to Norton_cad's Avatar
    2007-05
    Bardwell Valley, Sydney, Australia
    433
    Default Re: Shading and hiddne lines
    Settings > phases & create a new phase. In view properties select which phase is current, and what filters you want. (new and previous, etc)
    Ohm's Law - Electricity follows the path of least resistance.
    Regards,
    Mark Norton,
    2012-03
    18
    First I was just going to say tryed it but AI went back and looked!
    Boom! There was automatic overrides put in by default cleared those and bang spot on.
    Thanks Appreciate the effort.
    Good karma your way --------------->
  1. shading
    By eveofdestruction in forum AutoCAD General
    Last Post: 2009-12-09, 06:17 PM
  2. Replies: 0
    Last Post: 2008-10-16, 10:26 PM
  3. Shading Help.
    By mjohnson.88569 in forum Revit MEP - General
    Last Post: 2007-10-02, 03:44 PM
  4. Shading
    By kimlance in forum AutoCAD General
    Last Post: 2007-05-07, 07:39 PM
  5. Shading again
    By tonyisenhoff in forum Revit Architecture - General
    Last Post: 2004-06-10, 09:29 PM
