Thread: Block editor "in place" transparency
    Active Member CADKid's Avatar
    2005-08
    New England
    54
    Default Block editor "in place" transparency
    Does anyone know how to adjust the transparency of background objects when executing the "Block editor in place" command? I'm using Arch 2013 and I edit blocks in place to move objects according to walls and other objects not in the block. This command is very helpful to me for my use however the background objects are very tough to see as if the transparency is set to high. I get errors when trying to upload screenshot, sorry. Any help would be greatly appreciated.
    Thank you in advance!
    2012-05
    28
    Default Re: Block editor "in place" transparency
    In Options > Display > Reference Edit fading intensity...
    2005-08
    New England
    54
    Fantastic! Fixed my issue. Thank you Blackfish, I always try the system variables first and forget about the options box! I truly appreciate the help, but hate when I can't figure it out on my own!
  1. Replies: 0
  2. if filter text equals "*" insert block "*"
    By d_m_hopper in forum AutoLISP
    Last Post: 2009-04-24, 05:46 PM
  3. Dynamic Block Implementation and "Authoring Palettes" Vs "Tool Palettes"?
    By sschwartz85916 in forum Dynamic Blocks - Technical
    Last Post: 2006-12-06, 08:03 PM
  4. HOW switch COMMAND "BLOCK" THE "Scale Uniformly"
    By viz_ken1030 in forum AutoLISP
    Last Post: 2006-11-17, 12:41 PM
  5. Be carefull with "close block editor"
    By r424andy in forum Dynamic Blocks - Technical
    Last Post: 2006-01-23, 07:46 PM
