Thread: Help me FIXO
    Member clxramos583784's Avatar
    2012-06
    27
    Default Help me FIXO
    How do I manipulate this variable by vb6 or vba to change value ?
    I would like change a lot of mleader on graphic screen and I intend change all in the same time.
    Is it possible ?
    Thanks !
    AUGI Addict fixo's Avatar
    2005-05
    Pietari, Venäjä
    1,227
    Default Re: Help me FIXO
    You can change two properties height and space factor:
    Public Sub ChangeLineSpaceFactor()
        Dim pickPt
        Dim oEnt As AcadEntity
        Dim oLeader As AcadMLeader
         Dim txtHgt As Double
     Dim dblLts As Double
          Dim setObj As AcadSelectionSet
         Dim setColl As AcadSelectionSets
         Dim setName As String
         Dim gpCode(0) As Integer
         Dim dataValue(0) As Variant
         Dim dxfcode, dxfdata
         gpCode(0) = 0
         dataValue(0) = "MULTILEADER"
         dxfcode = gpCode: dxfdata = dataValue
         setName = "$MleaderSelect$"
      On Error GoTo Err_Control
           With ThisDrawing
              Set setColl = .SelectionSets
              For Each setObj In setColl
                   If setObj.Name = setName Then
                        .SelectionSets.Item(setName).Delete
                        Exit For
                   End If
              Next
              Set setObj = .SelectionSets.Add(setName)
         End With
         setObj.SelectOnScreen dxfcode, dxfdata
         setObj.Highlight True
         MsgBox "Selected: " & CStr(setObj.Count & " mleaders")
         If setObj.Count > 0 Then
         ' >> do your changes here :
         For Each oEnt In setObj
              Set oLeader = oEnt
              Set oLeader = oEnt
        txtHgt = oLeader.TextHeight
        dblLts = oLeader.LinetypeScale
          oLeader.TextHeight = txtHgt * 6
      oLeader.LinetypeScale = dblLts * 6
         Next
        End If
    Err_Control:
        If Err.Number <> 0 Then
        MsgBox Err.Description
        End If
    End Sub
    ~'J'~
    "The whole problem with the world is that fools and fanatics are always
    so certain of themselves, and wiser people so full of doubts."
    Bertrand Russell
    2012-06
    27
    Thanks very much !
    "You are the Man"
    2005-05
    Pietari, Venäjä
    1,227
    Glad you got it working,
    Cheers
    ~'J'~
    Bertrand Russell
