Thread: Trying to add window option to overhead door
    2004-06
    Memphis TN area
    6,719
    Default Trying to add window option to overhead door
    I'm trying to add the option of having view windows in our overhead sectional door family. I set up an array for number of windows of 2 or more, then a single center window for one, and visibility parameters controlling the single and the array, all of which are controlled by a "Number of Windows" integer parameter.
    I have a separate "WindowNum" integer with a formula that keeps the array number at a minimum of 2 (if Number of Windows is 1 or 0) so that the array doesn't break. However even if I set Number of Windows to 1 or 0, it says the parameter has an invalid value. Can't seem to reconcile this thing. Any ideas?
    Intern Architect, BIM Manager/Coordinator
    AERC, PLLC
    Hernando, Mississippi
    Revit - all up in your voxel space
    2007-07
    5
    Default Re: Trying to add window option to overhead door
    You need to create another parameter for your array so that the arrays value doesn't go below 2. I created a parameter "Number of windows array" with the formula "if(Number of Windows < 2, 2, Number of Windows)" and assigned that one to the array and it's working fine.
    See attachment created with student version of RAC 2012.
    2004-06
    Memphis TN area
    6,719
    Oops, I forgot to set the array to my WindowNum parameter. I already did earlier what you suggested, just forgot to set the array itself to the correct parameter.
    AERC, PLLC
  1. Overhead Door question
    By Chris.N in forum Revit Architecture - Families
    Last Post: 2008-04-08, 06:33 PM
  2. Glass overhead door anyone?
    By J. Grouchy in forum Revit Architecture - Families
    Last Post: 2008-04-01, 01:03 PM
  3. Overhead door to cut foundation
    By bengo in forum Revit Architecture - General
    Last Post: 2008-03-14, 09:10 PM
  4. overhead door
    By PHOTOS4ME in forum ACA General
    Last Post: 2007-12-20, 02:10 PM
  5. Overhead door track
    By bgarrett in forum Revit Architecture - General
    Last Post: 2006-11-14, 10:04 PM
