Thread: Keep override even if dimension change
    Wish List Administration
    2011-08
    4,584
    Default Keep override even if dimension change
    Summary: It would be usefull to be able to keep override text even if we change the dimension "witness lines"
    Description: I would like to be able to change the witness lines of a dimensions, that is overrided, and to can keep the override active and don't have to write it back again.
    Product and Feature: Revit Structure - Annotation Tools
    Submitted By: evalucia_87 on 07/04/2012
    2013-04
    8
    Default Re: Keep override even if dimension change
    Instead of the warning coming up that tells you the override will be removed, it could ask you to keep the override or remove it.
    2011-08
    4,584
    Exclamation Re: Keep override even if dimension change
  1. Global dimension override
    By bohoon1809732 in forum AutoLISP
    Last Post: 2014-02-11, 04:38 PM
  2. Dimension override
    By bob.parker in forum Revit Architecture - General
    Last Post: 2008-04-19, 09:13 PM
  3. use this family for when you need a dimension override
    By Justin Marchiel in forum Revit Architecture - Families
    Last Post: 2007-09-07, 06:09 PM
  4. Dimension Override
    By bmccabe.65836 in forum Revit Architecture - General
    Last Post: 2005-03-08, 07:43 PM
  5. Dimension Override
    By bmccabe.65836 in forum Revit Architecture - Tips & Tricks
