Thread: Plug-ins
    2011-12
    23
    Default Plug-ins
    Hello,
    Please, point me in the right direction if I am not in the appropriate forum.
    How do I plug-in the Civil menu package to AutoCAD 2012 Standard version? Any imput will be greatly appreciated. Thanks
    Cairo - no, not Illinois
    5,069
    Default Re: Plug-ins
    You're going to have to clarify a bit -- exactly what 'Civil menu package" are you talking about? From which vendor?
    Civil 3d is a separate product, and can't simply be installed as an add-on to the vanilla (aka "Standard") version of AutoCAD, it has to be installed on its own.
    2009-11
    5,714
    1+
    ... Sounds like a Carlson Survey, Eagle Point, etc., if this is a civil plug-in for AutoCAD (and not a vertical).
    Computer Specs:
    2011-12
    23
    Hi AUGIE Addict,
    Thanks for responding. The vendor is Autodesk.
    So, the issue is bigger than I thought. I am contributing dwgs to ProjectWise (PW), a Bentley product. This product only works with the Standard version of AutoCAD 2012, not with 3D Civil AutoCAD 2012. I have created/automated plan profile sheets using surface files (Tin files) which PW cannot read. I thought the solution would be to enhance the Standard version of AutoCAD 2012. But, if it cannot be done. Then, would it be possible enhance PW instead?
    ee22
    5,069
    You'll need to get with your Bentley reseller to find out what can be doen with Projectwise, there's nothing on the Autodesk side that can be done AFAIK
  1. Plug-ins without Navisworks
    By masiefert in forum NavisWorks - General
    Last Post: 2009-07-14, 06:51 PM
  2. Need old voloview plug-in?
    By jgratton in forum AutoCAD 3D (2007 and above)
    Last Post: 2007-10-03, 03:04 AM
  3. Plug-In
    By burninin1 in forum Inventor - General
    Last Post: 2007-08-06, 02:27 AM
  4. Brazil plug-in for Max/Viz
    By kpaxton in forum Revit - Gallery
    Last Post: 2005-09-09, 02:43 PM
  5. No cd yet, where can I get the viz plug-in?
    By Wagurto in forum Revit Architecture - General
    Last Post: 2005-01-11, 07:35 PM
