Summary: To be able to align the center of a wall's foundation with an axe and not only the center of the wall.
Description: Add a parameter to let us set an offset from the center of the wall (or with option like "center of wall", "axe", "ref. line"...), to align the center of a foundation elsewhere without using retaining footing.
When you have two diff. width in a same wall (the wall is offset) and 2 foundations of the same type, that need to be centered to the axe and not to the wall centerline, you need to make 2-types of fondations.
Product and Feature: Revit Structure - Other
Submitted By: evalucia_87 on 07/06/2012
