Results 1 to 7 of 7
Thread: Column Grids
    2007-12
    Wichita, Kansas
    10
    Default Column Grids
    I am having a problem propagating the grid to all my levels. In the dialog box that pops up to check which plans you want to propagate it to it does not show all of my plans. What is weird is that I have a ground floor level and it will let me propagate to the ground floor RCP but not the ground floor plan. Any ideas of what is going on would be appreciated.
    2005-07
    Somewhere in the BIM world
    3,792
    Default Re: Column Grids
    Could some views be set to a specific Scope Box?
    2015-11
    Jo'burg SA
    4,512
    Are the grids perhaps set to a Scope Box?
    2009-03
    Somerville, MA
    1,060
    I seem to remember that even if the views are just cropped, Scope Box or not, it won't propagate grid extents... can't remember for sure, though.
    2007-12
    Wichita, Kansas
    10
    No views are set to a specific scope box, column grid not set to a scope box and I looked into the cropped views and no luck with that either.
    2007-12
    Wichita, Kansas
    10
    Thanks to one of my friends his answer is this and it worked:
    The grids’ physical extents only touch levels “1st Floor” through “3rd Floor”, and apparently Propagate Extents can only work on levels that the grids physically intersect.
    So, if you go into section or elevation and drag the extents so the grids stretch across all levels, then you can propagate their extents to all levels.
    2004-05
    St. Louis, Missouri
    3,135
    Yep. Good one. I've seen LOTS of users having this same problem.
  1. 2013: Revising Column Grids
    By gsteffen642486 in forum Revit Architecture - General
    Last Post: 2013-08-28, 04:38 PM
  2. Structural Column Grids
    By medwards.119413 in forum ACA Wish List
    Last Post: 2008-10-08, 10:20 PM
  3. Column Grids
    By dzatto in forum ACA General
    Last Post: 2007-12-26, 10:51 PM
  4. Column Grid Lines and Shifting Column Grids
    By .chad in forum ACA General
    Last Post: 2007-11-02, 03:42 PM
  5. Curved Column Grids
    By Steve_Stafford in forum Revit Architecture - General
    Last Post: 2003-05-09, 10:18 PM
