Thread: over-ride the over-rides
    Wish List Administration
    2011-08
    4,584
    0 Did you find this post helpful? Yes
    Default over-ride the over-rides
    Summary: It would help a lot if the XREF attachement included toggles to ignore display property over-rides, such as colors, from displaying in attached/overlain reference files
    Description: Everyone know that using by-entity colors, linetypes, ltscales, etc. causes problems when a file containing the over-ridden entities is used as a reference file. But it happens, over and over again. What I would like to see is an option in the XREF attach process to selectively ignore Color, Lineweight, Plotstyle & LTScale over-rides that have been applied to any entities in a drawing, and only display and manage them on a by-layer basis.
    While it's possible to open the reference file as a drawing, and run SETBYLAYER, that action changes the file, which may well have come from an outside party. I'd like to be able to use those files as references, while not being forced to edit what my subconsultants did. Basically toggles that enforce 'display bylayer only', rather than whatever over-rides were done.
    Product and Feature: AutoCAD - XREF
    Submitted By: Jim Gerth on 07/11/2012
    0,0,0 The Origin
    8,560
    Default Re: over-ride the over-rides
    Sounds like a winner.
    John B
    2011-08
    4,584
    Exclamation Re: over-ride the over-rides
    The wish has already been granted. This thread is closed to further posts.
  1. Formula over rides for display
    By Wish List System in forum Revit MEP - Wish List
    Last Post: 2014-04-21, 04:48 PM
  2. Alignment Subcomponents & Child Over Rides
    By tim_newsome in forum AutoCAD Civil 3D - General
    Last Post: 2012-10-25, 01:12 PM
  3. Phase filter over rides messing with Filter over rides
    By tim.101799 in forum Revit Architecture - General
    Last Post: 2008-10-30, 08:20 PM
  4. problem with phase graphic over rides
    Last Post: 2007-06-23, 03:43 PM
  5. Dim Over rides
    By kmadsen in forum ACA FAQ (Read only)
    Last Post: 2007-02-28, 07:08 PM
