Thread: Revit 2013 Structural Framing - Structural Usage Differences
    2009-12
    Brisbane, Australia
    4
    Default Revit 2013 Structural Framing - Structural Usage Differences
    When looking at the structural usage of framing members I am getting different usages on different computers using Revit Structure 2013. The model has been upgraded from a 2012 version, on one PC the structural usages in the instance properties and VG window appear as 'Girder, Joist, Other, Purlin' etc. but when the same model is viewed on other PC's they appear as 'Primary, Secondary, Tertiary'.
    Everything still appears to be functioning properly.
    Has anyone else come across this?
    2001-12
    Irvine, CA
    7,567
    Default Re: Revit 2013 Structural Framing - Structural Usage Differences
    Sounds like different language/localization installs. The terms Primary, Secondary, Tertiary are UK or locales other than North America or the Imperial content... that might account for the difference if various pc's have different installs?? Seeing that you are in Brisbane did a NA Imperial install sneak into your office? Did it get installed before the AUS content was posted?
    2009-12
    Brisbane, Australia
    4
    This seemed to fix it. I've unistalled and reinstalled using the deployment that was used to install on all other PC's. I'd initially installed my Revit version off of the CD before a deployment was created. Thanks for the tip.
  1. Revit Structural plan framing
    By 7386061985 in forum Revit Structure - General
    Last Post: 2012-06-05, 01:01 PM
  2. Structural usage - Non-bearing structural walls
    By Bryan Thatcher in forum Revit Structure - General
    Last Post: 2010-08-26, 07:51 PM
  3. Structural Framing - Structural Usage
    By Davied2 in forum Revit Architecture - General
    Last Post: 2010-04-07, 08:45 AM
  4. Structural Usage
    By Tim Bosman in forum Revit Structure - General
    Last Post: 2009-08-13, 10:56 PM
  5. Structural Usage
    By codya137484 in forum Revit Structure - Families
    Last Post: 2009-03-29, 11:34 PM
Tags for this Thread
