Thread: Link Underlay causes link to turn Halftone.
    100 Club lzaras's Avatar
    2001-03
    United States, next to a Lake
    136
    Default Link Underlay causes link to turn Halftone.
    Why?
    I am working in a project that we upgraded from 2012 to 2013. In 2012, I had filters set up to show a piece of the Architectural link (a generic model; elevated seating slabs) would show as solid linework in my sections.
    Basically,
    • I left the overall Halftone of the link as unchecked. But set the link as an underlay.
    • Then, I set the link to Custom and I took every model element in the Architectural link except Generic Models and set them to halftone.
    • Then created filters to grab the specific generic models I wanted on and turned all the others off.
    • Then I created a view template that I could re-use on other, similar sections.
    In 2013, the Underlay feature seems to have an additional "feature" that is unwanted. When I set the Architectural link to Underlay, it does send the file under my structural model, but it also makes the underlay HALFTONE! So, I cannot get that piece of generic model to show solid. Why have the additional Halftone checkbox if the Underlay is going to do that anyway?
    I tried with a new project, linking the same Architectural model and cutting the same section. When I set the link to underlay, it turns halftone, too! Also, tried changing from Structural to Coordination with no change.
    2001-03
    136
    Default Re: Link Underlay causes link to turn Halftone.
    UPDATE:
    To turn off automatic Halftoning of the Underlay feature, go to
    Manage Tab > Settings Panel > Additional Settings pulldown > Halftone / Underlay dialog box
    and uncheck the "Apply Halftone" checkbox.
  1. Replies: 0
    Last Post: 2012-01-11, 09:42 PM
  2. Link Underlay
    By trialbyfire in forum Revit Structure - General
    Last Post: 2011-06-10, 12:28 PM
  3. Replies: 3
    Last Post: 2009-10-20, 12:28 AM
  4. Toposurface ( how to turn off in architects link)
    By kathey1 in forum Revit Structure - General
    Last Post: 2009-07-29, 02:12 PM
Tags for this Thread
