I have several manholes in a network and would like to set the surface adjustment for all of them at once rather than setting it for each one individualy. Any help?
Are you just trying to set it to a reference surface? You can do that through the Panorama.
The following steps occur within the Panorama.
- Select all of the structures or pipes to be changed
- then right-click on the Reference Surface column name
- select Edit...
- choose the desired surface
Select one structure, right-click and Select Similar.
Properties Window.
