Thread: DWG Export Settings Was UP!?
    2004-05
    792
    Unhappy DWG Export Settings Was UP!?
    I went to export a revit file v7 (latest build) into a dwg file (default template) as a test for someone standing here. I went to load the AIA standards, good so far, and then I noticed that it had loaded or kept from somewhere, layers that I have not used in over a year from multpile projects, entire xref sets, whole car and truck compnonets, even greek layers.
    Any thoughts?
    I have never done a save as to change this setting.
    It's like it has kept every layer that I have ever done or imported. Very strange.
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    Default Re: DWG Export Settings Was UP!?
    Any time you import a dwg or add new subcategories revit automatically adds them to the export list so you can control them on export. I have gotten rid of them but I can't remember how, I just don't worry about them anymore, they don't affect anything. I think if you open the export template file in notepad, you can delete them from there, but if those categories are in your revit template, they will come back.
    Scott D. Brown, AIA
    BECK
    2004-05
    792
    Right you are! I found the little text file in notepad and got rid of over 250 layers in just one spot in the text file.
    thanks.
    All AUGI, all the time jbalding48677's Avatar
    2003-05
    Irvine, CA
    765
    SJSL -
    Looks like a purge command for the layers.txt file is in order??? Have you submitted this as wishlist item?
    - JB
    - JB
  1. 2012: DWG Export settings
    By mcgregorl243981 in forum Revit Structure - General
    Last Post: 2013-01-28, 02:42 PM
  2. Export settings
    By ford347 in forum Revit Architecture - General
    Last Post: 2006-08-22, 12:09 AM
  3. Export to DWG Settings
    By matt.98118 in forum Revit Architecture - General
    Last Post: 2006-03-10, 01:05 AM
  4. AIA Export to DWG Color Settings
    By Scott D Davis in forum Revit Architecture - General
    Last Post: 2004-08-04, 08:25 PM
  5. Export settings
    By christo4robin in forum Revit Architecture - General
    Last Post: 2003-06-19, 06:35 PM
