Thread: 2013 Cursor does not appear
    2012-01
    4
    Default 2013 Cursor does not appear
    We just Switched to 2013. I will have 2 files open, Elevation and the Plan. When I switch to the plan file the cursor will not appear, but if i pick a random point in the file it acknowleges it. Just can't see it prior to picking. Any ideas?
    Cairo - no, not Illinois
    2,718
    Default Re: 2013 Cursor does not appear
    Options command, check display colors - make sure the crosshairs are not the same color as the background. then check SNAP command, and verify that the size is not larger than the drawing area. Then, possibly display adaptor/driver may need updating.
    Officially Awesome
  1. Revit 2013 Detail Views Showing up in Navisworks 2013
    By tfullerpipes in forum NavisWorks - General
    Last Post: 2013-01-30, 06:37 AM
  2. Exportar Revit 2012-2013 a 3ds Max Design 2013...
    By magdagarciavinuesa in forum Español - Revit
    Last Post: 2012-06-23, 12:02 PM
  3. Cursor Problem
    By bowtle in forum AutoCAD 3D (2007 and above)
    Last Post: 2010-02-08, 10:16 PM
  4. Cursor Question
    By janunson in forum Revit Architecture - General
    Last Post: 2007-01-17, 10:19 PM
  5. cursor cannot be seen
    By shaon9902 in forum AutoCAD Map 3D - General
    Last Post: 2006-10-18, 07:57 AM
