Results 1 to 10 of 14
Thread: What happened to the "Edit" command
    100 Club mikehaff's Avatar
    2010-10
    120
    Default What happened to the "Edit" command
    The edit command was used to open a text file within autocad. Was it replaced by something else?
    2006-04
    (0,0,+|Z|)
    1,119
    Default Re: What happened to the "Edit" command
    The command is "DDedit".
    Enter "aliasedit" you'll find the shortcut for "DDedit" is "ED" unless you had modified it.
    2010-10
    120
    Thank you for your input. However, you misunderstood my post. The "Edit" command was used to open an external text file outside of AutoCAD. That's what I need to do.
    2001-03
    Tallahassee, FL
    1,098
    Edit was the editor for windows later replaced by notepad. We used to shell out to DOS from AutoCAD to edit lisp and script files, but Edit isn't included in Windows anymore. I remember using AutoCAD's Edlin command to create a linetype way back when.
    Tom Beauford P.S.M. - Civil 2013 on Windows 7 Pro
    Design Analysis - Leon County Public Works/Engineering
    Ph# (850)606-1516
    2010-10
    120
    Thank you Tom. I too remember edlin. Ok. Notepad works, but isn't there a way to switch to a different text editor? I can't seem to find it.
    2001-03
    Tallahassee, FL
    1,098
    I have TextPad as my default editor for most files in Windows 7. The macro for starting Acaddoc.lsp is:
    ^C^C_start;acaddoc.lsp;
    Which uses the default editor and for me opens it in TextPad.
    Ph# (850)606-1516
    100 Club JeffClark's Avatar
    2002-07
    South Jersey
    101
    Ah.....the memories...I havn't heard "Edlin" in years!
    0,0,0 The Origin
    8,027
    I remember using AutoCAD's Edlin command ...
    AutoCAD's Edlin command?
    It was part of MS-DOS.
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
    Houston
    7,519
    Quote Originally Posted by mikehaff View Post
    It was defined in the ACAD.PGP file, sometime prior to the 2008 version.
    Here is a link to a version that includes this line: http://www.cabrillo.edu/~gmarcoccia/acad.pgp , if you want to copy it into your PGP file. Make sure "Edit" is a valid executable.
    Here is the 2008 version that shows it was not included: http://web.acd.ccac.edu/~dference/edd222/acad.pgp
    100 Club moshira_hassan's Avatar
    2003-01
    125
    use the command "dtexted" and change the variable to 0
  1. apply command does not apply in "edit rail"
    By ray salmon in forum Revit Architecture - General
    Last Post: 2008-12-16, 05:21 PM
  2. What happened to "Apply to layers toolbar" check box?
    By stelthorst in forum AMEP General
    Last Post: 2007-09-13, 03:10 PM
  3. HOW switch COMMAND "BLOCK" THE "Scale Uniformly"
    By viz_ken1030 in forum AutoLISP
    Last Post: 2006-11-17, 11:41 AM
  4. Replies: 3
    Last Post: 2006-03-23, 09:25 PM
