Thread: MEP Spaces
    2005-02
    CT, USA
    19
    Default MEP Spaces
    Hi all,
    I am having trouble with getting spaces into an MEP model with a linked architectural model. This is a phased project and I have matched the MEP phases with the architectural. Room bounding is on. Rooms exist in the architectural model and I am able to create spaces in the architectural model. When I hit the space button in the MEP model, Revit spins it's wheels for quite a while before it allows me to put in a space that doesn't have valid boundaries. I have gotten an error saying the space computation has failed but I can't duplicate that every time. When I expand that message it says consider editting the architectural link. I don't see any plan regions but room separations were used extensively. I have not tried doing anything with them, yet.
    Any suggestions would be appreciated.
    Rob
    2009-07
    Seattle, WA
    73
    Default Re: MEP Spaces
    Do you have the MEP phases mapped to the Arch phases? If not, you'll need to do this by selecting the Arch link, edit type (like when you checked Room Bounding), then click the Phase Mapping button. Not sure if this is your problem, but it's something to try.
    2005-02
    CT, USA
    19
    The mapping wasn't correct and I had just finished correcting it when I got your responce. Still no joy. I have however stopped the spinning wheel by removing all CAD links.
    2005-02
    CT, USA
    19
    Problem solved.
    Removed an inserted CAD object and viola, it works.
  1. Spaces to cope with vertically irregular spaces better
    By Wish List System in forum Revit MEP - Wish List
    Last Post: 2015-12-05, 08:10 PM
  2. 2010: Spaces
    By Heather_W in forum ACA General
    Last Post: 2014-01-02, 04:21 PM
  3. Spaces
    By dzatto in forum ACA General
    Last Post: 2007-10-23, 11:28 PM
  4. Spaces
    By pangell in forum ACA General
    Last Post: 2005-12-22, 03:19 PM
  5. Spaces
    By gdaniels in forum ACA General
    Last Post: 2005-11-10, 09:52 PM
