Results 1 to 9 of 9
Thread: Dim Text Offset Problem ?
    2011-12
    Default Dim Text Offset Problem ?
    Hi
    I want to change dim text offset of the drawing zone with lisp. how can I do it?
    Active Member nod684's Avatar
    2008-09
    Singapore
    63
    Default Re: Dim Text Offset Problem ?
    Quote Originally Posted by eren_esm731604 View Post
    Hi
    try this :
    (defun c:test (/ )
    (setq cmd1 (getvar "cmdecho"))
    (setvar "cmdecho" 0)
    (setq DIMNEW (entsel "\n Select Dimension to Adjust Dimension Text Offset:"))
    (command "dimoverride" "dimgap" "3" "" DIMNEW) <<<<----- change the "3" to your desired text offset
    (setvar "cmdecho" cmd1)
    "Memories fade but the scars still linger..."
    2011-12
    that is what I am looking for. thanks a lot.
    2008-09
    Singapore
    63
    No problem!
    2012-06
    9
    I've modified nod684's code a bit : credit goes to nod still for the help...
    This will enable you to input your desired Txt Offset and will also enable you to select multiple dimensions that you want to change :
    (defun c:test (/ )
    (setq TOffset (getreal "\nEnter Desired Text Offset :  "))
    (prompt "\nSelect Dimension to Adjust Dimension Text Offset:")
    	(while
    		(if (setq en (ssget '((0 . "DIMENSION"))))
    			(command "dimoverride" "dimgap" TOffset "" en "")
    		(Princ "\nNo Dimensions selected! Try again!")
    (princ "\nDone!")
    (princ))
    2008-09
    Singapore
    63
    Quote Originally Posted by meandyoulagi367990 View Post
    (defun c:test (/ )
    	(while
    (princ "\nDone!")
    (princ))
    thanks meandyou...i was thinking bout this
    but my one was done in a jiffy
    in fact haven't had time to check if working or not lolz!
    try this one; with Dimension Height as default Dimgap :
    (defun c:test (/ )
    (setq dimtxt (getvar "Dimtxt"))
    (setq TOffset (getreal "\nEnter Desired Text Offset :  <" (rtos Dimtxt) "> "))
    (if (= TOffset  nil) (setq TOffset  dimtxt))
    	(while
    (princ "\nDone!")
    (princ))
    2012-06
    9
    Quote Originally Posted by nod684 View Post
    (defun c:test (/ )
    	(while
    (princ "\nDone!")
    (princ))
    now that's better! thanks for the addition
    I could stop if I wanted to Tharwat's Avatar
    2010-06
    483
    @nod684
    Localizing variables is very important in all routines , except when it is needed globally for any specific case.
    2008-09
    Singapore
    63
    Quote Originally Posted by Tharwat View Post
    @nod684
    Noted Tharwat thanks for the reminder...
  1. Family Offset from Wall Problem...
    By USMCBody in forum Revit MEP - Families
    Last Post: 2012-07-23, 08:10 PM
  2. Dimension Text Offset
    By brent.130528 in forum Revit Architecture - General
    Last Post: 2009-08-17, 05:37 PM
  3. Base offset problem with roofs
    By joe.138576 in forum Revit Architecture - General
    Last Post: 2007-07-18, 09:41 PM
