Results 1 to 9 of 9
Thread: Revit Server 2012 and 2013
    AUGI Addict MikeJarosz's Avatar
    2015-10
    New York NY
    1,497
    Default Revit Server 2012 and 2013
    We are currently setting up Revit server on new server hardware as recommended by Autodesk. We have a consultant doing the installation. We currently have all but one of our projects on 2012, but our joint venture partners and MEP engineers want us to move up to 2013. This will require us to invest in new machines for our users. (Win 7, 64 bits, you all know the specs). I asked about 2013 on XP a few weeks back and everyone agreed it won't work very well.
    The network consultant tells us that Autodesk did a lot of work on the Revit server in release 2013 and it is a much better product. But we consult on projects all over the US and expect to have projects that are not always on the latest version. I anticipate we will need 2012 and 2013 simultaneously. We also have a 2011 project, but that can't use the server at all. And, 2014 isn't far away......
    Can the Revit Server 2012 and 2013 coexist on the same server, with project X using 2012 and project Y using 2013? We would never mix files. That is a well established principle with Revit.
    Does anyone have it set up this way? How is it working?
    Certifiable AUGI Addict
    2004-05
    St. Louis, Missouri
    3,135
    Default Re: Revit Server 2012 and 2013
    Yes--they can run side-by side. It is 2 completely different installs. We are doing this next week, to test out RS 2013 before bringing it into production.
    Make sure to read THIS: http://wikihelp.autodesk.com/Revit/e...78-Installi178
    100 Club pdavis's Avatar
    2005-01
    Tampa, Fl
    188
    We have one Revit Server 2012 and 2013 running on the same central server with Clarity installed with no issues. Our other Revit Server 2012 and 2013 deployments are on separate VM's. We do not notice any performance issues or benefits in either case.
    2015-10
    New York NY
    1,497
    Quote Originally Posted by cliff collins View Post
    Thanks. We're starting to configure it now. My first startup with R2013 crashed. I have to run upgrade 1!
    2008-09
    Nebraska & Iowa
    378
    What does something like this cost? License for Revit Server + VM Ware + Xeon 2-Quad core Server + Windows Server 2008 R2?
    2004-05
    St. Louis, Missouri
    3,135
    RS software is "free"--i.e. it comes with Revit; VM ware--not sure about $, guess about $300-500; Xeon Quad Core server plan on about $1.5-2K, windows server 64 R2 about $800?
    I would budget about $3000-3500. (assuming you have Revit already) Lots of variables here, so plan conservatively.
    All AUGI, all the time robert.manna's Avatar
    2005-05
    Boston
    777
    Quote Originally Posted by rbcameron1 View Post
    You would only run Vmware if the server is also serving other functions, so therefore the total cost of the server hardware should not/would not be allocated to your Revit Server cost. On the other hand if you're going to just "buy" a box for Revit Server to run on, you don't Vmare. In that case the specs for that box are quite honestly all over the place. You'll note that Autodesk's guidance for hardware is either 100 users or less or 100 users or more. In my opinion both sets of specs are for the median. That is if you're only going to have in the neighborhood of 30 users hitting your infrastructure at any one time you could probably seriously decrease the required hardware to at most a very affordable $2,000 - $3,000 server. On the other hand, if you thought you were going to have substantially more than 100 users, I would probably go above and beyond what Autodesk has recommended. When you're dealing with virtual machines you have to take into account what your other load is going to be in addition to Revit Server. It really is allow about load more than anything. Revit Server itself will run on pitifully low end hardware and support easily a dozen users working on medium size projects, the issues come up when you start dealing with many active projects which likely equals many active users and then also the scope and size of those projects, for instance a multi-million square foot hospital replacement or campus type setting with everything modeled, blah, blah, blah.... Versus a couple of dorm and classroom buildings.
    I could stop if I wanted to TroyGates's Avatar
    2015-08
    Irvine, CA
    281
    Quote Originally Posted by MikeJarosz View Post
    Revit 2011 models can be saved on Revit Server 2012. You just need the subscription download to enable it in Revit 2011.
    2008-09
    Nebraska & Iowa
    378
    ok, that's what I was wondering if RS was on its own server, we don't need VM. I like the RS is free answer Cliff. Free if you pay for subscription.
    thanks guys
  1. Exportar Revit 2012-2013 a 3ds Max Design 2013...
    By magdagarciavinuesa in forum Revit Architecture - General
    Last Post: 2015-02-04, 10:34 PM
  2. 2013: Revit Server 2013 on Windows Server 2012
    By l.southwood350110 in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2014-08-01, 08:19 AM
  3. Revit Server 2013
    By nick.beaven in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2012-10-24, 02:29 AM
  4. 2012: Is Revit Architecture Viewer 2012 incompatible with Revit Server 2012?
    By meng005 in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2012-08-27, 08:45 PM
  5. Connecting Vault basic 2013 client to vault 2012 server
    By eradityabjoshi in forum Vault - General
    Last Post: 2012-05-30, 08:05 AM
