Thread: Walls under Style Manager/Display Properties
    Wish List Administration
    2011-08
    4,581
    Default Walls under Style Manager/Display Properties
    Summary: showing object override for a wall
    Description: It would be great to have a flag indicate that the wall you are exploring under Style Manager/Display Properties has an object override.
    Product and Feature: AutoCAD Architecture - Walls
    Submitted By: Melinda Heavrin on 08/15/2012
    2003-03
    Philadelphia, PA
    2,392
    Default Re: Walls under Style Manager/Display Properties
    Quote Originally Posted by Wish List System View Post
    I do not understand how this could work. If you are in the Style Manager, looking at the display properties of a Wall Style (or any other object style), there is no specific object involved, so how would ACA know to indicate whether or not there was an object override? Or is the intent to indicate that at least one instance of the style has an object-level override?
    2002-12
    271
    Yes I get David's point. I think if you select a wall (or anything) and it has an object override, relevant perhaps to the display rep you are in, you could have some type of warning flag /ed exclamation device telling you there is an override to the selected entity. So many times I have raged because a change won't show only to find it has an OO. So no, not from the Style Manager. Only if you have an entity selected and you try to edit it's properties.
    btw there was an excellent (by the sound of it) style manager editor around that should have been bought up by adesk and packaged with the product. Did you have something to do with that one David? Did you review it? It's now out of date I think and no longer updated, the creator moved on to Revit by the sound of it.
    2003-03
    Philadelphia, PA
    2,392
    I helped to beta test it. It was quite good, but even before the Revit steamroller came through, sales were not sufficiently robust to justify continuing development, from what I gather.
    You can semi-quickly check to see if there is an object override by either editing an objects display properties or by selecting the object and looking at the Display tab of the Properties palette. If two or more Display Representations are active in the current Display Representation Set, the latter could be more tedious, unless the one with the override just happened to be the default one to display. But I agree, some sort of on-screen icon that would show when an object was seletected if there were object level display overrides on an active Display Representation would be nice. That way you would not have to remember to look for an override.
    2011-08
    4,581
    Exclamation Re: Walls under Style Manager/Display Properties
    Walls Under Style Manager/Display Properties
    Submitted By: melindaheavrin on 08/15/2012
  1. Replies: 0
    Last Post: 2015-04-15, 07:25 PM
  2. icons in Style/Display Manager
    By Bryan Thatcher in forum ACA General
    Last Post: 2010-06-09, 04:01 PM
  3. No Properties Manager display
    By Sponge Bob in forum AutoCAD General
    Last Post: 2010-03-04, 02:26 AM
  4. Don't see properties for Display Manager styles for AutoCAD entities.
    By Glenn Pope in forum AutoCAD Map 3D - General
    Last Post: 2009-09-08, 05:39 PM
  5. Multiple Wall Style Display Properties
    By Marv Muston in forum Style Management
    Last Post: 2006-06-01, 12:01 PM
