In prevoius versions of AutoCAD i have closed the document with CloseAndDiscard. This is not an option in AutoCAD 2013. What do I do?
Dim doc As Autodesk.AutoCAD.ApplicationServices.Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
Try
Dim db As Autodesk.AutoCAD.DatabaseServices.Database = doc.Database
If FileName_N_Path = General.BrAs.NotSet Then db.Save() Else db.SaveAs(FileName_N_Path, db.OriginalFileVersion)
doc.CloseAndDiscard()
Catch ex As Exception
End Try
doc = Nothing
