Results 1 to 10 of 10
Thread: Populating Forms (Combo Boxes, Check Boxesk) Passing Arguments between forms
    2011-06
    28
    Default Populating Forms (Combo Boxes, Check Boxesk) Passing Arguments between forms
    Please forgive me, I am very green...
    I am developing application level macros (I guess you know that by now) for RST 2011. Now I want to create and populate some forms.
    Creating the forms, I got it. Populating the forms with data from the model...not a clue.
    I have used drop-downs, but I cannot figure out how to link model data to the form. Can I even do this in an application macro? If not, that's fine, I'll try it in a proper add-in.
    So, the question stands, how do i link model data with the form? I see there is a data source option, where I can browse around and add data, but I still can't get it to populate (I usually receive an error message in German- something about a module...)
    Also, how do I pass the information between forms and other 'pieces' of my add-in. I've seen this done with a class which references the document, but beyond that I haven't a clue how to do this...
    Does any of this text make sense?
    Any help is greatly appreciated.
    Matt
    2004-06
    Port Moody, BC
    349
    Default Re: Populating Forms (Combo Boxes, Check Boxesk) Passing Arguments between forms
    I am by no means an expert, however here is what I would do as a fellow greeny!
    I will use a combo box as an example and populate with WallType Names:
    Define the form with a combo box, name the combo box cboDrew (or whatever)
    Get the list of Wall Types from the document
    For each walltype, put its name into the combo box
    show the form.
    I use vb, so here is a sort of example:
    Dim myfrm As New Form1
    Dim collector As New Autodesk.Revit.DB.FilteredElementCollector(doc)
    Dim collection As ICollection(Of Autodesk.Revit.DB.Element) = collector.OfClass(GetType(Autodesk.Revit.DB.WallType)).ToElements()
    For Each Walltype As WallType In collection
    myfrm.cboDrew.Items.Add(Walltype.Name.ToString)
    Next
    myfrm.ShowDialog()
    Am I in the correct ball park for what you were looking for?
    2011-06
    28
    I will try it on the way home tonight...thanks for the reply.
    I'll let you know how it turns-out.
    Matt
    Turlock, CA
    6,419
    That's the usual method for populating a control. As to the DataSource property, that takes a DataSet as an argument. This sets up automatic data binding for the form. Controls can then access tables, etc from the dataset. This is intended for an SQL table or database.
    C:> ED WORKING....
    LinkedIn
    2011-06
    28
    I have not tried this yet (no time) but I'm starting to look a little more into forms. I've used the form-designer from VSTA in the past, but that was months ago, and I never go anything actually running.
    What is still unclear to me:
    I want to take information from the form, and bring it back into my application macros. The form is an object within the project, but I am running all of my code from the ThisApplication.vb (object / module?)
    How do I get the information from the form, into ThisApplication.vb?
    I've tried Call and CallbyName, but that doesn't seem to work.
    Can anyone explain how this works?
    Thanks.
    Matt
    2011-06
    28
    It looks like you are in the right ballpark...but I cannot access the ICollection object. Where does it come from?
    2011-06
    28
    Decided to check back on this topic. ICollection - in which namespace can I find this object?!?
    2011-06
    28
    Bump.
    Does anyone know where I can find the ICollection object (as mentioned by drewj)?
    Matt
    Turlock, CA
    6,419
    His code is using Generics to cast a bunch of Element objects into a collection. If you are trying to find objects in the framework, use Object Browser. Search for iCollection and find out what class it belongs to (Hint: System.Collections), then add a reference to the class and an Imports statement to the declarations section of your code.
    C:> ED WORKING....
    LinkedIn
    2011-01
    87
    I think the easiest method is to write a temporary tab or comma delimited file then delete it when you're done. This is how I overcame a large dataset from 11 parameters from an unlimited elements selection set. It worked very well and I could sort it within the file so when I loaded the form, it was sorted.
  1. Using Windows Forms vb
    By drewj in forum Revit - API
    Last Post: 2012-07-19, 08:43 PM
  2. Some Void Forms...
    By brent.130528 in forum Revit Architecture - General
    Last Post: 2010-01-27, 12:15 AM
  3. Populating combo box created on the fly
    By gdaniels in forum VBA/COM Interop
    Last Post: 2008-04-26, 04:42 PM
  4. The Different Forms of 3d
    By mlawler in forum DV - The 3rd Dimension
    Last Post: 2005-12-12, 09:22 AM
  5. Passing selection sets as arguments
    By mcoonrod in forum AutoLISP
    Last Post: 2005-10-21, 05:51 PM
