Another question about doors. I tend to use instance parameters to control most things with door families because I like to avoid having a long list of components on the drop down selector when placing doors.
However, my new firm wants to do a door elevation legend and a frame elevation legend showing all the panel types and frame types used on the job.
I know that Revit has a feature called Legend Component that allows you to place an elevation view of different components into a legend. However, it only allows you to place the different types, not different instances, of the doors in the project. If I use instance parameters to reduce the list of doors on the drop down, then I won't be able to show all required conditions in the legend.
Can you help me think this through? Am I missing something? Is there a better way? Type catalogue, perhaps?
Thanks in advance.
