Thread: run external executable file in autocad wit command startapp
    2012-08
    Default run external executable file in autocad wit command startapp
    I Need advice on how to run external executable file (creat from c++) in autocad with command startapp
    6,421
    Default Re: run external executable file in autocad wit command startapp
    By "executable", I assume you mean *.exe. You can't run code from another thread inside the same process as autocad. The c++ code must be compiled as an ObjectArx dll. Then you can load it with the lisp (arxload) function.
    LinkedIn
    Tallahassee, FL USA
    3,667
    You could shell out to an executable:
     (command "sh" "C:\\Program Files\\Autodesk Map 5\\Vlisp\\Tableprint8.exe")
    I start a few of them in my CUI that way.
    2,095
    Huh? I run a few EXE's with (startapp...) calls, I just don't expect them to return anything. Syntax is important, including wrapping double-quotes to handle spaces in the path name.
    2015-11
    Jo'burg SA
    4,512
    Yep, and even if it's an EXE it might be registered as an ActiveX object. Thus you can link to it using vlax-get-or-create-object. Like lots do with Excel.
  1. Replies: 3
    Last Post: 2014-11-14, 08:39 AM
  2. cannot run external command
    By b.glendenning in forum Revit - API
    Last Post: 2009-12-14, 05:50 PM
  3. how do I run an external ARX command thru' VBA
    By pravin.pai in forum VBA/COM Interop
    Last Post: 2009-08-27, 03:30 PM
  4. Replies: 5
    Last Post: 2009-07-09, 10:23 AM
  5. No External Command
    By mschroeder in forum Revit - Student Support
    Last Post: 2008-12-05, 04:52 PM
