Thread: opening a .dwg OR .dwt file AND saveas with a lisp routine
    2012-05
    5
    Default opening a .dwg OR .dwt file AND saveas with a lisp routine
    Does anyone have a lisp routine to open a template or drawing file in one folder, and save it as another name in another folder? This would help in setting up a new project. The routine I've pasted below stops working immediately after:
    (command "open" "S:/Drawing Template/Sheet Template.dwg"
    It seems the lisp routine needs something between: (Sheet Template.dwg" and "saveas" "2010")
    (defun c:project setup ()
    (command "SDI" 1)
    (command "FILEDIA" 0)
    "saveas" "2010" "S:/Project/B-1.dwg")
    (command "tilemode" "0" "layer" "s" "0" ""
    "xref" "a" "xtblk30x42=x-tblk 30x42.dwg" "0,0,0" "1" "" "0"
    "INSERT" "SHEETNO=S:/Drawing Template/Sheet No" "0,0,0" "1" "" "0" "zoom" "e")
    (command "explode" "L")
    (command "filedia" 1)
    (PRINC))
    Thanks for your help!
    Last edited by mmccollum661679; 2012-08-23 at 09:12 PM. Reason: [code] tags added ~Opie
    Tallahassee, FL USA
    3,667
    Default Re: opening a .dwg OR .dwt file AND saveas with a lisp routine
    Lisp must be loaded and run in a single drawing session. What you need to do is copy the file with lisp, script or shell to a batch file, then activate the file with something like:
     (defun MyOpen (FileName ReadOnly / )
      (vla-activate
        (vla-Open
          (vla-get-Documents  (vlax-get-Acad-Object))
          FileName
          (if ReadOnly :vlax-true :vlax-false)
    ; wye.dwg
    ; (MyOpen "G:\\TOMBU\\EaglePointProjects\\CntrvleTrace\\wye.dwg" nil)
    ; (MyOpen "G:/TOMBU/EaglePointProjects/CntrvleTrace/wye.dwg" nil)
    ;|(MyOpen (strcat (getvar "roamablerootprefix")"Support" (chr 92) "acaddoc.lsp") nil)(princ))
    (MyOpen "C:\\Documents and Settings\\User\\Application Data\\Autodesk\\AutoCAD Map 3D 2008\\R17.1\\enu\\support\\acaddoc.lsp" nil)
    ^C^C^P(or C:ViewBox(load "ViewBox.lsp"));ViewBox
    ^C^C^P(or C:MyOpen(load "MyOpen.lsp"));(MyOpen "G:/TOMBU/Blocks/Leon_County_Plans_Binder.dwg" nil)(princ)
    ^C^C^P(or C:MyOpen(load "MyOpen.lsp"));(MyOpen (getenv "QnewTemplate") nil)(princ)
    ^C^C^P(or C:MyOpen(load "MyOpen.lsp"));(MyOpen (strcat (getvar "localrootprefix") "template" (chr 92) "map2d_Leon.dwt") nil)(princ)
    ^C^C^P(or C:MyOpen(load "MyOpen.lsp"));(MyOpen (strcat (getvar "localrootprefix") "template" (chr 92) "FLHP-NF.dwt") nil)(princ)
    ^C^C^P(or C:MyOpen(load "MyOpen.lsp"));(MyOpen "FLHP-NF.dwt" nil)(princ)
    ^C^C^P(or C:MyOpen(load "MyOpen.lsp"));(MyOpen "" nil)(princ)
    ^C^C^P(or C:MyOpen(load "MyOpen.lsp"));(MyOpen "acaddoc.lsp" nil)(princ)
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,103
    Why not create a drawing template that has the xref already attached and the block inserted and exploded? You could then copy that template using the vl-file-copy function to create your project drawing.
  1. Set file name from block attribute with lisp routine
    By email.dnewton396831 in forum AutoLISP
    Last Post: 2013-07-03, 08:51 PM
  2. Use Saveas Command from a Lisp Routine
    By CADdancer in forum AutoLISP
    Last Post: 2011-06-23, 03:01 PM
  3. Replies: 4
    Last Post: 2008-12-03, 06:39 AM
  4. A LISP routine for runing a batch file ?
    By stephen.coff in forum AutoLISP
    Last Post: 2006-09-07, 02:40 AM
  5. xref file relocation lisp routine
    By kgano in forum AutoLISP
    Last Post: 2005-04-15, 12:24 PM
