Thread: Startup Dialogue Box
    2003-03
    129
    Default Startup Dialogue Box
    Could someone explain to me why the startup dialog box wouldn't show up even after Tools->Options->System->Show Traditional Startup Dialog is chosen? Is a puzzlement! Thanks!
    150700
    3,421
    Default Re: Startup Dialogue Box
    Check to make sure your filedia variable is set to 1
    Type: Integer
    Saved in: Registry
    Initial Value: 0
    Controls whether the Create New Drawing dialog box is displayed when starting a new drawing with the NEW and QNEW commands. Also controls whether the Startup dialog box is displayed when the application is started.
    If the FILEDIA system variable is set to 0, no dialog boxes are displayed.
    0 Displays the Select Template dialog box, or uses a default drawing template file set in the Options dialog box, on the Files tab.
    1 Displays the Startup and the Create New Drawing dialog boxes.
  1. dialogue box
    By gailc in forum AutoCAD Map 3D - General
    Last Post: 2010-04-18, 11:46 PM
  2. Dialogue Boxes
    By fjtdogeno in forum AutoCAD General
    Last Post: 2009-03-06, 07:20 AM
  3. No dialogue box...
    By Longtnguyen in forum Revit - Platform
    Last Post: 2009-01-20, 01:46 PM
  4. Do you use the AutoCAD 2007 Startup dialogue?
    By Steve Johnson in forum AutoCAD General
    Last Post: 2006-08-11, 05:39 PM
  5. Can't get the viewport dialogue box
    By jgh in forum AutoCAD General
    Last Post: 2005-12-23, 12:52 PM
