Thread: Tapering Rebar, Slanted Rebar, Alternately placed and Alternately Staggered Rebar
    Wish List Administration
    2011-08
    4,581
    Default Tapering Rebar, Slanted Rebar, Alternately placed and Alternately Staggered Rebar
    Summary: I want to be able to place reinforcement by object hosting or path Reinforcement in slabs and walls with Tapering Rebar, Slanted Rebar, Alternately placed and Alternately Staggered Rebar/
    Description: I have been using CADS RC and Revit for years now ang I finally got around to setting up my Revit template and schedules to work similar to CADS RC. The only limitation I have found to date are 1: If the top of my walls are slanted the rebar will not slope with the top surface. This has stopped my using it on retaining walls, bridge wingwalls and core over runs. 2: I can't use Revit rebar to detail to Euro code flat slabs where we typically detail with Alternately stagger and Alternately placed bars. If these can be fixed I won't need CADS RC.
    Product and Feature: Revit Structure - Reinforcement (individual
    Submitted By: Stephen Whelan on 08/27/2012
    2011-08
    4,581
    Exclamation Re: Tapering Rebar, Slanted Rebar, Alternately placed and Alternately Staggered Rebar
    Summary: I want to be able to place reinforcement by object hosting or path Reinforcement in slabs and walls with Tapering Rebar, Slanted Rebar, Alternately placed and Alternately Staggered Rebar.
    Description: I have been using CADS RC and Revit for years now and I finally got around to setting up my Revit template and schedules to work similar to CADS RC. The only limitation I have found to date are 1: If the top of my walls are slanted the rebar will not slope with the top surface. This has stopped my using it on retaining walls, bridge wingwalls and core over runs. 2: I can't use Revit rebar to detail to Euro code flat slabs where we typically detail with Alternately stagger and Alternately placed bars. If these can be fixed I won't need CADS RC.
  1. 2014: Rebar Detailing to Get Rebar Schedule & 2D details
    By Intan in forum Revit Structure - General
    Last Post: 2014-05-05, 07:02 AM
  2. Add ability to add Rebar with an extension similar to Geopak Rebar or Rbar
    By Wish List System in forum Revit Structure - Wish List
    Last Post: 2012-07-09, 04:31 PM
  3. ASD rebar
    By andrew.boardman1 in forum AutoCAD Structural Detailing
    Last Post: 2011-08-30, 05:53 AM
  4. API for rebar
    By nvphatbk in forum Revit - API
    Last Post: 2007-11-06, 08:30 AM
  5. RS3 rebar
    By tvanniekerk in forum Revit Structure - General
    Last Post: 2006-04-26, 06:24 AM
