Thread: How do I rotate points, then align, and move the selected points
    2012-08
    Default How do I rotate points, then align, and move the selected points
    How do I rotate points, then align, and move the selected points. I tried this using align command but it only rotated the text and did not change the coordinates in the database. I am using Land Desktop 2004. I asked this question in another AutoCAD forum and I get many views but zero replys. Can someone help? Please.
    2014-08
    447
    Default Re: How do I rotate points, then align, and move the selected points
    HI
    been a while since I used LDD unfortunately. to move the points you need to look under the point tab on the menu bar. I think your going to look for translate like I said been awhile. then you will find the rotate points command in the same menu. be careful with the rotate, it is very specific on how to enter the degrees to rotate
  1. 2015: HELP! Points don't align with lines in linked CAD survey
    By sqlar in forum Revit Architecture - General
    Last Post: 2015-01-21, 10:04 PM
  2. Align/Scale point symbols between two points
    Last Post: 2010-11-20, 12:57 PM
  3. Dimension points do not move when using the Move command
    By sudhirkizhakoote in forum AutoCAD General
    Last Post: 2005-10-16, 05:33 PM
  4. Topography: Align Points
    By Scott D Davis in forum Revit Architecture - Wish List
    Last Post: 2005-02-28, 06:11 PM
