I've been working on a building with structural foundation slabs and structural slab edges. The Ground Floor Plan views correctly. When creating an Area Plan of the same Ground Floor level (either Gross Floor or Rentable) the slab edge is now incorrectly visible through the structural foundation slab. All view settings are the same (I think). The foundation slab is also now showing the concrete surface pattern in a light gray pen style in the Area Plan instead of the normal black pen style as in the Ground Floor view.
- What setting in Area Plan is forcing structural slab visibility settings to change? It's as if it's being ghosted.
- Am I missing a basic understanding of structural foundation slabs or area plans?
- Are they not intended for use in Area Plans?
- Should I draft a normal floor over every foundation slab and then hide the slabs in Area Plan views?
