Thread: Edit Color Scheme on Volume Surface
    2008-10
    Bel Air, MD
    15
    Default Edit Color Scheme on Volume Surface
    Hello,
    In the following tutorial video for Civil 3D 2013 they show how to do a basic cut fill map.
    http://docs.autodesk.com/CIV3D/2013/...dashboard.html
    I would like to change the colors, I know they can be changed one by one, picking new colors, however I am not artistic and the ones I pick do not blend well light to dark.
    In the example 1ft of cut is Dark Red and 6ft of cut is light red & 1ft of fill is light green & 4ft of fill is dark green
    I would like to reverse the red colors so 1ft of cut is light red and 6ft of cut is dark red. This makes much more sense to me.
    I would actualy prefer and red/blue cut/fill map, but I would be more than happy with red and green if I could get the colors to shade correctly.
    Is there a way to get the "Color Scheme" to fill in these colors?
    2012-08
    New York, New York
    6
    Default Re: Edit Color Scheme on Volume Surface
    I've gotten a bit better at picking colors when needed, so I'm not sure if this works because its been a while, but if you go to Toolspace > Settings > Surface > Surface Styles > (your surface style, such as 'elevation banding 2d') > Analysis Tab > Elevation dropdown > Change Range Color Scheme to rainbow. You may need to in the Surface Properties > Analysis tab : select to use the range color scheme.
    Have fun with colors!
  1. 2014: Color Scheme Not Visible Over Floor with Surface Pattern
    By Millawi in forum Revit Architecture - General
    Last Post: 2014-04-21, 09:34 PM
  2. Edit Color Scheme Values
    Last Post: 2013-10-24, 08:31 PM
  3. Edit Color Scheme Values
    By DaveP in forum Revit - Platform
    Last Post: 2008-06-09, 09:33 PM
  4. can I create a color scheme for surface analysis by elevation?
    By dness in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2007-06-07, 09:28 PM
  5. Can't add color to Edit Color Scheme
    By Steve Jager in forum Revit Architecture - General
    Last Post: 2006-07-23, 05:22 PM
