My co-worker can publish layout tabs but my work station can't. Is there a setting I need to check?
~Kurt
~Kurt
What steps are you taking to try and publish? what error message do you get? same drawing or different drawings? acad version or vertical versions? plotter model/driver?
cadtag - It was my SDI setting. It was set to <0> which is standard. I change the setting to <1> and now I can select my layout tabs and publish. And still use my LDT tools (Civil, Survey, Pipeworks....etc)
Thanks, that is not something I would have guessed as being responsible.
