Thread: split spline in lowest point
    2012-03
    Default split spline in lowest point
    Could somebody write me a routine which would split a spline in it's lowest point, please?
    I could stop if I wanted to Tharwat's Avatar
    2010-06
    483
    Default Re: split spline in lowest point
    Can you explain more in details please ?
    Tharwat
    2012-03
    I need to split a parabola like this one (unknown start and end)
    http://www.google.hr/imgres?start=24...13,s:247,i:204
    into 2 pieces in it's lowest point.
    I've been working all day on a somewhat mathematical solution (putting a horizontal line inside of the parabola, then putting a vertical line in the center of the horizontal one and breaking the spline (parabola) in the intersection of the vertical line and the spline).
    I was hoping someone with more programming skill could help me with a more elegant solution (one which works on splines of any type)
    Ontario, Canada
    84
    Give this a try...
    (defun c:foo ( / MAXPT MINPT OLDOSMODE PTA SPLINEOBJ VLA-SPLINEOBJ)
      (setq splineobj (car (entsel))
    	vla-splineobj (vlax-ename->vla-object splineobj)
    	); setq
      (vlax-invoke-method vla-splineobj 'getboundingbox 'minpt 'maxpt)
      (setq pta (vlax-curve-getclosestpointtoprojection
    	      vla-splineobj
    	      (list 0.0 (- (cadr (vlax-safearray->list minpt)) 10.0) 0.0)
    	      (list 1.0 0.0 0.0)
    	      nil
    	      ); vlax-curve-getclosestpointtoprojection
    	oldosmode (getvar "osmode")
    	); setq
      (setvar "osmode" (boole 7 (getvar "osmode") 16384))
      (vl-cmdf "break" splineobj pta pta)
      (setvar "osmode" oldosmode)
      ); defun
    Note that it is absolutely bare-bones, with no error handling, and assumes that there is only one "lowest" point on the curve.
    2012-03
    thank you
  1. Generic model hosted by lowest level when copied/arrayed
    Last Post: 2012-03-23, 03:12 PM
  2. Combine Surfaces-Use lowest elevation
    By epipkin in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2010-08-05, 04:47 PM
  3. Lowest Wall Height
    Last Post: 2009-07-27, 07:56 PM
  4. Lowest of two surfaces
    By joao.nuncio in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2009-04-08, 03:09 PM
