Thread: AutoCAD installer launches when other programs are opened.
    2001-08
    13
    Unhappy AutoCAD installer launches when other programs are opened.
    For some reason the AutoCAD installer is launching when I open other programs. Has anyone run into this issue? Any info would be extremely appreciated! Thanks!!!
    Alex Kallianidis
    CAD Coordinator/Operator
    North Atlantic Corp.
    Phone: 508-235-4297 800-543-5403
    Fax: 508-235-4436
    E Mail: mailto:Akall@northatlanticcorp.com
    2001-05
    Austin, TX USA
    2,201
    Default Re: AutoCAD installer launches when other programs are opened.
    I have had this problem a couple of times. Usually with freeware programs I was trying out. I didn't worry to much about it since I didn't like these programs and uninstalled them. Then it wasn't a problem any more.
    I did some searching and found a few others having the same problem. There just wasn't any solutions. There were a couple saying to uninstall AutoCAD and reinstall it.
    13,656
    Hi
    Have a browse of the following thread -
    Installer keeps loading
    Have a good one, Mike
    Digital Delivery Director Brian Myers's Avatar
    2003-02
    Stillwater, Oklahoma
    1,819
    I had the same problem with my AutoCAD installation. It appears to be a Registry issue, unfortunately I've never found the best solution. I've even un-installed and re-installed it.. same problem.
    Finally I uninstalled it, restarted, then cleaned the registry using a registry cleaner.. restarted again and installed. It didn't happen again.
    So likely my solution was over-kill, but it did finally help...
    But WHY does this happen? I'm not sure why the install created the issue, but it seemed to be something in the way the CAD installation wrote itself to the registry.
  1. DE311-2: Signed, Sealed and Delivered: Writing an Installer for Your AutoCAD Application
    Last Post: 2013-05-05, 01:36 PM
  2. Replies: 3
    Last Post: 2007-09-07, 04:36 PM
  3. AutoCAD closes as soon as it is opened
    By amanda_duvall in forum AutoCAD General
    Last Post: 2007-06-19, 07:39 PM
  4. Create an installer to run modules in AutoCAD
    By tany0070 in forum AutoLISP
    Last Post: 2007-05-28, 05:44 AM
  5. Can a PDF be opened and inserted into AutoCAD
    By cadop.89229 in forum AutoCAD General
    Last Post: 2007-01-10, 05:14 PM
